You need to find out what is leaking, not sure if you are gonna hear it unless you have super sensitive hearing. If you have a mitivac you can check each component separately and might also want to pull the control at the dash and do some checking there. There are three or four vacuum pods that can leak but you also need to check the lines and the vacuum reservoir under the hood.
I have a work truck that had been eating vacuum pumps for several years now and I finally took the time to fix it. The pumps are expensive and don't last very long when running nonstop. On mine it was a bad pod down at the passenger footwell.
