Ok,
They are saying put the dowl here.
Now drop the push rods into these cylinders
Mr. Owner if you have the dowl in this position one of these two cylinders is going to be at top dead center on the compression stroke.
Mr. Owner we can't tell you which because if you rotate that crank 360 degrees the dowl will be in that position and now the other cylinder is at top dead center on the compression stroke.
So you determin which of these two cylinders' push rods are of equal height indicating no valve lift and with that dowl in that position THAT cylinder is in the top dead center position on the compression stroke.
Now we have identified that cylinder as X torque and go strait over to cylinders T, N , Z torquing them.
Substitute my letters for the numbers they supply.
Once they have been torqued they direct you to the others.
