Rize suggest to use a 4.5 backspace with their lifts. I found a wheel that I want to use that has a 6.09 backspace on a 10 inch rim. Am i giong to make more rubbing issues for myself?
How bad will it be? I plan to run a 14 inch wide tire.
Turn your wheel and measure over the ammount that the new wheels and tires will be offset to the inside. For measureing the dia and width to the fenderwells make a block that reflects the added width and dia. and place it on the tread and check your clearences.
Cary
