Hey guys,
Hopped in the '97 this morning and went to fire it up. Has a wicked romp that will just continue on unless I hit the throttle quick. After the first initial throttle hit, it will stay clear and run fine. But if I shut it off and fire it back up, it'll romp like crazy until I hit the throttle again, then it goes away. I found a slew of different causes ranging from HPOP issues to air leaks. I'm hoping it just just something like the IPR. It only started acting up bad today, and only twice before have I had ever had it romp. Those two times it would hit a single romp and level out on its own. Any suggestions would be great, we're going to be starting up harvest next weekend and I don't want to be down a truck.
Automatic tranny (couldn't determine from you profile or previous posts....)? If so, try starting it in Neutral. If that makes the romp go away, you need to test / adjust / poss. replace the TRS - Trans Range Switch (aka. neutral safety switch).
