Re: 2011 F250
Missing the body molding trim pieces, both sides, at rear of roof joint to body side panel. All that’s left is what appears to be rubber pad that separated from the original trim piece. I assuming this rubber glued, perhaps, to the body molding, and it’s attached to the roof with nuts on the inside of the truck maybe under headliner and edge molding.
Anyone experiencing similar traits? I found in a Ford Parts website the PNs for the R and L side parts, trim. So the question begs how are these rubber attachments removed, and new installed?
Thanks for any info, assist.
Discussion Starter #2
Looks like no one has this issue, and hence, got no reply. But if anyone did, or change them out, what did you do? I read where one fella took a grinder to the mounting screws/bolts and got tube of body moulding cement, dab some on and just stuck these moulding back to the cab top. Might work?
