1 - 10 of 10 Posts
Alright, don't laugh. But after I installed the 3" DP and 4" system from MBRP there is a rumbling noise from under the hood, sometimes at idle, and on decelleration. Is this normal? It doesn't sound like anything is hitting.
I should have done this a long time ago, what a difference.
Sounds like your downpipe is touching the firewall.
Definitely hitting the firewall when the cab/engine shifts. Keep bending!!!
Big prybar and some arm it will be fine I "clearanced" mine before I removed the stocker.
It was hitting. I just took the system down and put the porta power up there for some more bending. I have to get a new DP clamp. The bolt snapped when I removed it. Can I reposition it so the nut can be loosened with a socket? Or does it have to do on with bolt straight up and down?
Good deal!
1 - 10 of 10 Posts
