Hello all.
So found a leak in hoop lines and I replaced with new aftermarket. I had pulled the intake spider and also did a crossover. In order to put locktite on the fittings I blew air out of the oil logs to clean the threads so introduced a lot of air into the system. I know you must drive it hard for about 100 miles to clear the air but it’s been about 150-209 miles of hard driving still running rough and shaky and CEL light is still on. Haven’t scanned it as of yet but what are you alls opinion? Still got air maybe something else happened. What wiring should I make sure is plugged in? Anything else cause air in oil like symptoms?
