1 - 10 of 10 Posts
So, the old 95 PSD is running funny. Starts and idles fine, but is real doggy. Wont really run much past about 30 mph. I have been told that it could be the CAT or possibly a sensor relating to the accelerator. Thoughts?
THanks!
Clint
Have you checked the oil lately?....
Oil changed less than 500 miles ago. not low.
Need more info on the '95, dont see it in your sig. Does it crank up easily, any smoke? Does it smooth out after its warm? Is it chipped? Have you done any recent repairs?
Air filter clean & not sucked into the turbo?.....
Have you checked & or replaced the fuel filter?
Have you checked the fuel pressure at the Schraeder ?...
Disconnect the map sensor also and see if it makes a difference. It is located on the passengers side firewall. It has a boost line going to it and a wire connector. Disconnect the wire connector.
Guys, thanks for the replies. Turns out something was up with the oil. Since it had been changed recently I wasnt worried about it, but after checking many other things, an oil/filter change did it. Guess it pays to do it myself....wondering if I got hosed on the last oil changed, it was very black....
If someone else does your oil changes, write the date and milage on the oil filter.
Discussion Starter · #10 ·
In 500 miles /ubbthreads/images/graemlins/shrug.gif
It was the wrong oil i would think.
Bill
What im thinking is they didnt change the oil and told us they did.....There was a new sticker in the window, but writing the date/miles on the filter is a great idea.....All better now though. 270k plus on the 95 and it still runs like a champ!
1 - 10 of 10 Posts
