2005 F350...
I'm wondering if anyone has run into this problem and might know what's going on. Truck was running fine, started bucking, then all of a sudden died like it was out of fuel. If you immediately try to restart it, it won't start, but if you wait a few minutes it will then start and run normal for a minute or so then eventually throw an injector code #1 or #7, then die after another 30 seconds, like it's running out of fuel. You can do this exact scenario over and over. Bad fuel pump? The top fuel filter was checked, it looks fine.
When you initially turn the key on before you start it you can hear the glowplugs and also hear what I believe is the fuel pump. The fuel pump sounds strong initially but fades fast, not like the normal sound when turning the key on.
Thanks for any insight.
