Howdy! I recently bought a 2000 E350 Powerstroke that has a Greaser setup installed on it. It's missing the fuel tank, but everything else is said to be there. Thing is, I know NOTHING about this stuff. This is my first diesel, so I'm totally clueless. I've done some research, but have one big question (issue?).
I bought an oil filter and a fuel filter. Oil, no problem. Went to change the fuel filter and...no fuel bowl! Fuel hose is run directly from a valve on the frame to what looks like a distribution block in the valley. Just wondering if this is normal. How does the fuel (or WVO if used) get filtered? Is it fine to run like this or can I put a fuel bowl back in?
If you need any other info, please let me know. My van is laid up right now until I find out if I can drive it as is or if I might be hurting it by not having a fuel bowl.
Thanks!!!
this is what the fuel system should look like (see pic). now If modification where made to accommodate other type of fuel well I can't answer because I know nothing about bio diesel.
Personally I would reinstall a fuel bowl and use diesel instead of bio. filtering you fuel is a must
Please post clear pics of the parts otherwise we are just guessing...
