Have any of you replaced your drivers seat cushion (bottom)?
After 8+ years, I have reached the point where I've sitting on an angle vs. flat.
The cushion is available as an OEM replacement for approx. $150.00.
Can the cushion be replaced in the truck, or does the entire seat need to be removed?
Walt
You do need to take the seat out too work on it much easier then even trying to do it with the seat in the truck.
Thanks for your reply.
I will check with a local shop, as they do this for the CATV trucks in the area.
WALT
