1 - 10 of 10 Posts
Just got an '11 F350 and am still figuring out my maintenance schedule.
I always followed the Severe Duty schedule on my old 6.0 because it was a 6.0 and I did pull a trailer a bit more than I do currently.
My current situation: truck is daily driver (office is 10 miles away), in Florida, pulling a 14K 5th wheel approx. 500 miles round trip maybe 6-8 weekends a year. I also have a small 6x10 enclosed trailer that I pull around town maybe 2-3 days/month with a couple dirt bikes in it. Also, I never go off road.
Does that sound severe duty to you?
The severe service schedule never hurt anyone. The only reason to use the "normal" service schedule would be if you can't afford the severe schedule &, in my opinion, if you can't afford more frequent oil changes then you can't afford the truck anyway.
I have similar driving habits to yours, except my commute to work is further. However, I would just follow the OLM and change it when it says - about 7500 or so. I've been doing that for 100K miles in this truck. I do use synthetic, started with Rotella T6, switched to Mobil-1(because walmart was soldout of T6 at the time, bought the mobile-1, and never switched back).
It is my opinion that the 6.7 is not as sensitive to oil like the 6.0 was with the oil fired injectors.
With the expense of replacing the engine of any of the new trucks today, and the varying conditions one may come across during the period of an oil change, i vote severe service myself.. Really not that much more of an expense if you add it up over the average life of a vehicle.. It can also be a selling point for the next buyer..
Do any of you guys get an oil analysis from a company like Blackstone?
Its really the best way to tell.
Reactions: SkiSmuggs
Do any of you guys get an oil analysis from a company like Blackstone? Its really the best way to tell.
Yes; I used to use Blackstone, but I switched to Polaris for a few reasons:
  1. Blackstone has increased cost to $38 per test (including TBN) and Polaris is $19 per test (including TBN).
  2. Polaris is ISO certified and (as near as I can tell) Blackstone is not.
  3. Blackstone's "recommendations" read more like an anecdote than a scientific analysis of test results.
  4. Blackstone seems to be plagued with problems on the test results where they are often asked to re-run the test to ensure the results are accurate.
Reactions: ArcticDriver
Looking at the Polaris Lab web site, I do not see an option to perform tests one at a time. Did you just purchase a pack of 10?
Thanks,
Cale
I buy them through Amsoil. I will PM you the link (not sure if posting in the clear is inline with the board rules).
The severe service oil for the Ford Powerstroke is 5/40 full synthetic. I have run it always in all 5 of my Powerstrokes.
If Ford changes your oil they will put in Motorcraft 5/40 and when I do it myself I use Rotella 5/40 synthetic which you can buy at Walmart much cheaper. If you live in a cold winter climate as I do its much better for sub zero starting. And if you pull up one of the steepest climbs in the country pulling a 16k 5ver in summers 100 degree plus heat as I do it has a much higher thermal brake down temperature than dino oil. The overall protection it gives is simply a smart all around choice to protect your huge investment.
Also on a working truck I would always change dino oil at 3000 miles and with synthetic I extend with no concern to 5000 mile changes which reduces the actual cost to run the synthetic. Just use it. IMHO
1 - 10 of 10 Posts
