After spending an entire day rebuilding my fuel bowl with the best Guzzle has to offer only to have it start leaking again 2 weeks later I decided I was done with the POS fuel bowl.
Talked to Dennis about potential differences between the van and the truck, and ordered the post-pump filter kit, and fuel bowl delete with regulated return kit. He knocked off $50 and removed the two pre-fabbed return lines that are intended to go from the rear of the heads to the regulator. The installer is responsible to run the return line from the regulator with the truck kit so that hose is DIY anyway.
Originally we thought the filter mount in the kit (off the inspection cover on the trans) would work.
The kit is well done, all the hoses are teflon lined braided stainless with a clear flexible PVC tubing sleaving it to prevent the stainless from rubbing and damaging other components.
Since I had to do all my return hoses I went with the same hose from Discount Hydraulic Hose:
Discount Hydraulic Hose.com
SAE 100R14A, 5/16". I ordered 10 feet of hose, and only had ~ 3" left.
They sell (expensive) re-usable fittings for those hoses as well:
SAE 100R14 Reusable Hose Fittings > Discount Hydraulic Hose.com
JIC 37 degree 3/8 will connect directly to AN6, the difference is AN6 is mil spec (superior threads, and you can tell when you tighten them down).
I also uses 7/16" id 9/16"od fuel and lubricant PVC tubing from McMaster Carr (5187K74) to sleeve my lines as best I could. It's yellow, so I don't know if it is a bonus or not, but I can easily tell at a glance which lines are supply and which are return.
A note on fabing the lines, I wrapped the area where I was cutting with packing tape, then cut it (slowly) with a chop saw. Wrapped the cut end with a little more packing tape and used some liquid laundry detergent as lube and worked the PVC over it. PITA, but worth the effort.
My pile of parts:
My first step was to attempt mounting the filter as planned. My first step resulted in my first problem. The oil filter mounts closer on the van I guess b/c it immediately was interfered. My solution was to mount the filter off the side of the trans in two unused bolt holes (3/8 16tpi 1" bolts)
I made a mounting plate using 1/8" aluminum and then cut the bottom off the plate in the kit and used to mount the filter to my plate.
More to follow...
My pile of parts:
More to follow...
