I have a 97 "California" f350 7.3 that is experiencing a slight idle surge after its warmed up. The surge is not very strong, the RPM jumps a little and returns to normal idle. Any preventive tips out there would be helpful before it turns into something worse.
First thing I would do is unplug the ICP. That will set your default high oil pressure at 750 or so, and would/should eliminate the ICP as the culprit.
