1 - 14 of 14 Posts
Anybody have any good suggestions for sludge cleaning?
I was told Marvel Mystery oil or running a quart of diesel fuel with the oil fot 10 minutes.
anyone>
anyone?
:jester:
What maks you think you have sludge?
Basically just preventive. When i do an oil change, it turns dark within a couple of days. Just want to prevent buildup.
anyone>
anyone?
:jester:
Here ya go. Look up Auto-RX.com:thumbsup:---Rob:ford:
What he said, linky
Auto RX can't be beat for cleaning and seal conditioning
Change you oil and filter on a regular basis, use a diesel spec'ed oil and you need nothing else.
The black in the oil soon after an oil change is from soot and the oil being a high detergent type oil. My new motor was black soon after the rebuild and I know it was a clean motor. Its just the nature of the beast.
Not really so. Case in point.
I had two identical european diesels, one had 60k miles on a rebuild , had been run on synthetic since the rebuild and maintained religiously. I had to tear it down after a stuck thermostat issue forced a rebuild, and even with that kind of detergent cleaning, I had to spend the usual amount of time with the ring groove cleaner on each piston cleaning out all the soot and varnish out of the ring grooves
( with my arthritis, that meant about a week to get the pistons cleaned up ). The engine had begun to exhibit signs of some oil consumption ( obviously due to sticky rings after seeing the ring grooves and the buildup in the oil control rings)
The second engine had well over 250k miles on it, had been thoroughly neglected and was inhaling a qt of oil every 30 miles when I aquired it. Ran a few Auto Rx treatments and oil consumption went to well over 800 miles on a qt ( within acceptable range spec ) . A while later I had to tear that engine down due to an unrelated issue and use of the ring groove cleaner was not needed, I was ablle to clean up the pistons and rings with a spray can of brake parts cleaner!
So really, any old diesel could benefit from a good cleaning once in a while. You've got to remember, over the road tractors have ALL run bypass oil filters for decades which helps tremendously in their ability to fend off the soot issues.
If a Rx treatment was needed, IH and Ford would spec this for normal maintenance.
I'm going to put my two cents in.
The only sludge buildup I've found in my truck was the last time I changed the oil.
My oil-pan is bent upwards (doesn't affect the oil pressure) and I ran some extra 30 weight oil I had through the filler with the drain plug out of the pan to clean it out.
I definitively got some sort of thick crap out of the pan, but I felt it was material that never truly got drained out because of the bent pan.
I agree with Snotzalot- if it were truly good for engines, they would be spec'd from the respective engine manufacturers.
On a side note, think about all the crap that may or may not be lining the block walls and/or oil pan. Now suppose this stuff does what it's supposed to and cleans it off. Now you have some kind of aggressive detergent, plus lots of questionable particles floating around your oil galleys and bearings. Some of those passages are pretty small in diameter...you can put two and two together to figure out that you could be playing russian roulette.
1 - 14 of 14 Posts
