2012 6.7 Ford diesel 4 wheel drive new Turbo.
Scaned for everything... all pressures for fuel injectors you name it would scan all in spec... Uses no fluids... Does not get hot.. fuel mileage is good. no oil in charge tubes ...Turbo's new... On restart Smokes and then disappears after a couple of min....It doesn't do it all the time generally after towing a trailer..truck is deleted.. map sensor new and in spec ...intakes sensor new.. Intake Is resealed. Truck is deleted no EGR.. ccv good ...changed vacuum diaphram and spring it helped helped ..no excessive blow by.. Running 0 horsepower... stock delete tune .... btw egt is normal 600 on freeway 1000 towing up hill
