Thank you didn't ever realize it before, guess I never pulled out the dipstick while it was hotDiesels are high compression engines. You are going to get a moderate amount of blow by. This will exude from the dipstick tube or the oil fill tube when open. Otherwise, the fumes go through the doghouse into the intake tube before the turbo. Completely normal.
RT explained it perfectly. If you pull the oil fill cap when the engine is running and you can it puffing with excessive pressure, this may mean you have a compression/blow-by issue.Diesels are high compression engines. You are going to get a moderate amount of blow by. This will exude from the dipstick tube or the oil fill tube when open. Otherwise, the fumes go through the doghouse into the intake tube before the turbo. Completely normal.
True, thanks for the clarification. Do not want to freak him out, as small puffs are normal. It is pretty obvious when they are puffing too hard.And just so you don't freak out - you're going to see puffing from the oil fill tube. What Justin is talking about is excessive or forceful puffing, especially a big puff every 8 firings (that might be indicative of a broken ring or cracked piston). The rude and crude test for excessive blow by is to turn your cap upside down and set it on the oil fill tube. If you have enough blow by to blow the cap off - its too much. The more precise test is a manometer setup. Nobody does that except Ford dealerships and probably not much there.
