While trying to track down my vibration problem that surfaced after putting in my SMFW (previous post) I found that the passenger side rear injector harness was fried. I fixed it using new international parts (thanks to BlueMule for posting the part numbers on 7/7/05) but still had the problem so I had the truck scanned. The contribution test showed all 8 injectors were good but the "buzz" test showed a fault with injector #5. Apparently that means that the screw under the solenoid has worked loose causing the injector to fire incorrectly. Question: How the heck do you tighten that screw? If it can't be tightened, how do you get it out to replace it? I ohmed all eight solenoids and found them all to be 3.6 ohms (except first injector, driver side which ohmed at 5.0) so I don't believe that the solenoid itself is the problem. Any input/advice/diagnosis would be greatly appreciated...
Danzo
Danzo
