Ok...we took the camper out for our first outing this past Memorial Day weekend. It was also the first pull with my DI chip. We drove into a steady 20-25 mph headwind. Coming out of little creek valley my truck downshifted, EGT's skyrocketed and my SES light lit off. These are the codes that were left:
P1211......ICP not controllable, pressure above/below desired.
P1249......Wastegate fail steady state test
P1282......Excessive ICP
I'm guessing that the ICP errors are from my chip. What about the wastegate message? Is that an overboost indicator or a possible backpressure sensor problem?
I'm having Dave tone down my tow program to help keep EGT's in check while towing...but I would like to narrow down this P1249 code. On the trip back I shut the chip off(stock position), set the cruise at 65 mph...and had no issues what so ever. The truck ran perfectly and only downshifted once.
I'm really not in the mood to have to change out my turbo, or the wastegage solenoid and hoping that its just overboost. My boost guage at the time was showing 25 pounds and I thought the overboost error code set at 27 pounds. I also admit that a 1-2 pound error in my readings is not out of the question.
Anyway...all youze smart fellas please give me your opinions.
Dave
Dave
