I am going to install the springs and sonnax valve tomorrow morning. After reading the directions over, I have a question. The directions say to lubricate the plunger valve before you put in sleeve. Do you just coat it with some ATF?
Since I am dropping the valve body, will I still be able to just follow the draining procedure by pumping out with the engine? I measured everything and made marks in a bucket so I would think that you just run the engine till X amt. of quarts are pumped out. I could see there being a bit of air in the system after dropping the valve body thus giving you false air bubbles in the clear hose. But please correct me if I am wrong.
Oh, I can't find the thread, but how many in/lbs do you tighten the valve body to?? I think 18 rings a bell. Is that right?
Thanks for all your help! I hope I don't REALLY screw something up! Leaving for the Ozarks Sunday.
