Ok, so my clutch is in. But.................. I've got questions!!!!! When the tranny is in neutral clutch engaged I hear an extra rattle from right below me, I push in the clutch pedal and the noise is instantly gone. And one other noise, any RPM below 1,250 under slight acceleration or decel it almost sounds like grinding gears but everything is already engaged. So my question is are abnormal sounds normal, until I put a few more miles on the clutch? Theres only about 50 miles on the clutch right now
depending on what stage the clutch is yes. If you have one both springs and rubber isolators on the disc or solid hub as i do then there will be a rattle in neutral until slight pedal pressure and when in gear at low low rpm 900-1100. not gonna get much better with time though.
Its the Stage 2 clutch, and yes there is I beleive 4 isolaters and 2 springs. So I knew it would be alittle noisier
