Can anyone suggest what I should be looking for here? The Rear Axle sensor is clean and working... I do get the ABS light every now & then. I am also having some rear axle noise but the speedo is getting worse on downhill coasting.
If you listen carefully... you can hear what sounds like a bearing noise.
Here is the link to YouTube.
https://youtu.be/_ZRaJP0Pmk4
What codes do you get? I had an issue with VSS codes that turned out to be decayed wiring - http://www.thedieselstop.com/forums/f24/abs-codes-c1229-c1230-334730/
The rear axle noise sounds like your carrier bearings going out. Not the center support bearing that people mistakenly call a carrier bearing, but the actual carrier bearings in the differential.
