1 - 16 of 16 Posts
What super duty spring codes have you guys use on your sky rsk?
Rusty
I have V codes now and I will be trying X codes then i have 2 sets of Donahoe springs..5" and 7" I am gona play with /ubbthreads/images/graemlins/biggrin.gif I am gona go to 37x18" so need to get it up a little more.
Cary
I have super lift now. I was thing about changeing the front around to get the better ride I was just wondering fit springs to use to get the same ride height.
Rusty
My lift has a seconds set of blocks in the back and I cant tell if the fronts are adda leafs or a whole new set of springs but they are stiff.
Rusty
My lift has the stock blocks with 4" taller ones on top. Its a four inch lift. I'm deployed so I cannt really take measurements I wish I could but my truck is a few 1000 miles away.
Rusty
Hey Rusty, what are your opinions on that second block being in there? I just did this also but with a stock 2 inch and a aftermarket 3 1/2 inch block that I had laying around. The springs they sent me were wrong so I had no choice. I'm just not too sure about stacking blocks like that? Sorry about the hijack. Thanks, Dave
Why so wide?
My friend had the 17" wide TSL's and they are huge. He regrets it now because they stick out way too much.
37X14" would be more manegable in my opinion.
37 inch tire....18 inch wheel....not width
Discussion Starter · #12 ·
that the way I got it I guess you could find one really big block or get a set of springs and run no blocks
Yep that the choice or add a shackel flip in the rear. Look at my pics..V codes and a 4" block. I will be playing around with X codes and Donahoes 5+7" springs this summer.
Don't stack blocks!!! They have been know to pop out with not perty results.
Cary
Rusty
I had the exact setup as you. My front was about 1.5 inches lower after.
Chris, did you ever get your bumper put on? I was hoping for a pic with it done.
Why so wide?
I see, that makes more sense.
I thought the second number was the tires width, I didn't know it was also used to describe the tire/rim diameter.
1 - 16 of 16 Posts
