Hi all,
I'm considering a conversion from my 97 F250 Audo 2wd SRW to DRW. I use the truck primarily for towing a small open car trailer all year round and a 42' enclosed gooseneck in the summer, also for the usual home projects on the weekends. Truck has chip, exhuast, and built tranny, considering intercooler and injectors.
Current: 3.55 open Diff
Cons:
-Final drive too tall for towing the big trailer (to keep the power in the sweet spot I have to run 70-75 which feels too fast for the big trailer)
-Open diff sucks in any slippery conditions
-SRW scares me in case of a blow out with te big trailer
Pros:
-Good mpg because of the tall final drive
I'm considering a 4:10 drw (or possibly a 3:73? from a SD) with posi
Here are my questions:
Are drw better for traction than srw?
I think the 3:73 would be the best comprimise ratio, comments?
What will I loose for mpg drw vrs srw?
My rear end has new brakes, can I use those on a non SD rear drw rear end?
Do the SD rear ends bolt in, or do I need to fab (I can weld, just adds to the project)?
What is the difference between pick up and cab/body rear ends? Can they be converted?
Cons:
Pros:
