Recently our 1991 350 ambulance has been suffering some odd behavior. A few weeks ago it started to stall out after going up steep hills (in CO) after removing ones' foot from the acceleration pedal. It would then take a bunch of pedal pumps (usually never needs any to start cold) to start back up only staying running with the fuel pedal pressed slightly. If ones foot is taken off the pedal it will rough idle and then stall out. Then it takes a bunch of pumps to start again and the only way to drive it is to keep one foot on the fuel always pressed down slightly then use the other foot to brake, making sure not to take the foot off the fuel and have it stall out (very scary in a heavy ambulance in the mountains).
Taking into the fact the ambulance has been converted to run on SVO and likes biodiesel too, it seemed time to change the filters.
Once the filters were changed on both sides of the system, no luck, same problem.
Then we figured it might be the the lift pump. After doing some tests it seemed as if the lift pump was not functioning fully so it was painstakingly and carefully replaced with a NAPA one. After the ordeal, it cranked pretty much right up. Bleed air from the fuel line going into the injection pump and we seemed good to go. Drove it around for a few days with now problems and it cranked right up every time cool and warm.
Then it was down the mountain where it acted fine, was good all round town, then it just stalled out after comming up 15 miles of a steep road when I took my foot of the fuel pedal to apply the brake.
Apparently it wasn't the lift pump.
What is going on?
I had also ajusted the idle but that didn't seem to help as it still cuts out after a hard throttle and then removing the pressure from the fuel pedal.
We are suppose to leave for a big trip tomorrow and would hate to take the gas guzzler. Any body have any ideas?
Thanks.
What is going on?
Thanks.
