Original problem; With truck at normal op. temp., parked at friends & truck was off for approx 20-30 min. Started truck, "fired" up & stalled 1-2 seconds later, (never happened before), I attempted to restart 4-6 times & same, stall after 1-2 seconds. (I could hear fuel pump come on & shut off as normal) Was acting just as if was running out of fuel, (truck has full tank). As test, I left key on for about about 2-3 min, got lucky & truck started & stayed running. Drove home 5 miles & everything was normal.
Following day, after driving approx. 5 miles, motor began stumbling yet never fully stalled. I checked records & seen I forgot to do fuel filters @ 15,000 & had gone over by 6,000 miles. I got new filters, installed & primed as required. Truck started with no prob., allowed truck to idle up to normal op. temp., (about 10-15 min.), drove truck about 1 mi. & parked.
1 hour later, jumped in truck to go out & NO START. Try to re-prime 15-20 times, nothing. Batteries were getting workout so decided to take break & put on charger. 3 hrs. later & same, NO START.
Ideas please? TY
Note; Truck has 56,000 mi., No engine mods w/ exception of Sinister Coolant Filter
Discussion Starter · #2 ·
To add; I checked the engine mounted fuel filter & housing is full of fuel
I would start by checking fuel & HP oil pressures.
The fuel I drained look ****, (no water). I'm not sure how to check HP oil pressure.
I surrender, calling flatbed tomorrow & take to Ford service . Just hoping not big $$$$ issue.
The high pressure fuel regulator was to blame in my 6.0L. Replaced it, and everything ran to be expected. It was also leaking a minute amount of diesel that I could smell through the vents, but mistook it for an oil leak that didn't exist.
However, yes there is a however, about two months later it began showing the same (or similar) symptoms, except this time it left me stranded, twice. I blamed it on vaporlock when it would restart a half hour later and was able to limp it home. After a tow to the service center, it was found that the TPS (or one of them) needed replacement.
Hope this gives you an idea of what to possibly expect.
It was crankshaft position sensor.
