1 - 13 of 13 Posts
sorry first post is a problem. - great site - I love my '02 7.3 auto, 4 dr, 6 pos. chip, 105,000 mi. However, starting today engine stalls/dies every time when trans. is put in reverse and motor reaches approx. 1000 RPM. Runs great otherwise. CPS new - replaced by Ford mechanic today with no results - HPOP within the last 5,000 mi. What simple thing could it be? I know one of you has gone through this very thing. Need to tow my race car & trailer with this Friday morning. Thanks in advance. wldhrse
p.s - I've read the cold weather service bulliten on here and I don't think it applies right now as it's 98 degrees here in Oklahoma.
Ditto what Cool said - had the same problem after pulling a mountain pass and puking some fluid. Went to back up and it would die. Filled it up, and problem vanished.
MM
thanks, between my post and your replies I had noticed that suggestion in a D.S. search so I checked it and might have been about a 1/2 qt. low, so I added with no results -same problem still there. I also did a google search and found something about the trans. filter falling off of valvebody causing this prob? I guess that might give you the same symptoms as low fluid. I'm going to look @ that next. wldhrse
widhrse,
Let me know what you come up with. I'm have the same problem right now. It first started dying making a complete stop. It did it three times. Now it does it only in reverse. Doing research I haven't found out way its doing it. Talked to AAMCO they don't know why untill they pull it apart-$1000 to start. This weekend going to drop the pan and check the filter to see if any metal. I called Brain but he hasn't return my call yet for a new transmission or an easy fix. Any infor I'll find out I'll let you know.
Rob
changed/flushed trans. filter & fluid - no difference other than it seems to be stalling/ dying at approx. 200 RPM higher. Sounds kinda like a converter huh?
Mine is not stalling at any time but is having trouble finding gears once it runs for a couple minutes and loses gear going down the road. From the research I have done I think it may be the torque converter clutch solenoid. I have found some information where this was the problem for the same symptoms you are describing. Are you having any other problems with it finding gears or slow to go into gear?
I can't imagine how the torque converter clutch solenoid could in any way affect how and when the trans selects gears. It's not involved in that at all.
You could have a pump problem, or an internal leak, or a wiring problem to the other solenoids, or even something I haven't thought of. But the TCC? I can't see that being the problem.
problem solved - wire harness was chaffing on the lower bolt of the mass air bracket above driver's side valve cover when engine torqued in reverse. (see pic.) Bolt had backed out into the wire a bit also. The wire that was chaffing and grounding out happend to be the CPS signal wire also. wldhrse
p.s. trans. was ready for a flush anyway.
http://i34.photobucket.com/albums/d129/wldhrse133/Powerstroke/Powerstrokechaffe080907009.jpg
glad you found it...it is truly amazing how often the problem is so removed from the symtom and how it turns out to something so simple
Resurrecting this old thread to report that it helped me fix an intermittent performance issue with my '01.
When I bought my truck a few months ago it usually ran great. Every now and then it would start running poorly, down on power, can't maintain highway speeds, and blowing a little white smoke out the exhaust. Usually my basic troubleshooting of unplugging the DP Tuner corrected the problem. This week on Monday though, when I was headed home the truck would barely hit 55 mph. The was hardly any boost being generated and the egt's were real low. I parked it and borrowed a car from work to go home.
The next day it ran fine at lunch so in the evening I tried driving it home again (I commute 65 miles one way). The first couple of miles it ran great but then it would start running rough and then the Wait To Start, Check Engine, and Water In Fuel lights would all come on. They would go out and the truck would start running good again. This cycle kept on happening off and on so I parked it again and borrowed the work car once more.
I came home and started searching my symptoms and ran across this thread. I came back today and looked at the wires and bingo!!! The insulation on the orange wire was worn through and was shorting out on the valve cover (the paint on the cover was also worn through showing bare metal). A black wire was starting to wear through as well so I taped them both up with electrical tape and then tapped up the entire wire bundle to keep it from happening again. I plan on getting some plastic wire loom material and add it to the wire bundle like it should have been from the factory.
So far the truck is running like it should. Great information found here and Google is definitely my friend. :thumbsup:
Reactions: 69mach1377
I had the same issue on my 2002 F250 Longbed Extended Cab Duelly with 7.3L Diesel. Not a fluid issue or transmission filter issue. Ultimately figured out it was the fuse to the security system. Apparently there was high-resistence and it was acting funny. Eventually the fuse failed and disabled the truck. Replacedit and immediately the backup problem went away. Look in your manual for the fuse that goes to the security system and replace it.
1 - 13 of 13 Posts
