Let 1987 6.9 sit for a month or so. Had previously put new relay ( behind air cleaner) in and new gp's. Truck has 430,000 miles on it. Have had it since it was new. Was running ok before I let it sit. Got back home, put good charge on both batteries, cleaned posts, some new ground connectors. Now, when I turn the key the fusible links at the battery relay heat up pretty good and start smokin. Is it possible that relay is bad? Or have I got a ground somewhere down the line. Would surely appreciate some input here. thanks,
