helping a friend put a starter in his 06 E350 with the 6.0 diesel, the starter was removed by someone else and I was asked to put the new on back in.
the question I have is wiring, there is the positive wire from the battery that is hooked up to the starter selonoid, that part is easy, but there is another power wire that comes from behind the engine and looks to be a power supply for the ficm and so on, does this power wire for the engine harness supply, connect on the same terminal as the battery positive cable?
I am pretty sure that these two wires connect on the same terminal together, but scince I did not take it off I don't want to screw anything up
thanks in advance
If it has a ring terminal on it yes it connects to the positive battery cable. You will find a small stud on top of the positive terminal that it connects to. I will try to post a pic in the morning. There is one on each side. Drivers side goes in the cab to the fuse box I think. The pass side goes to the alt I think.
