Have an interesting issue with my starter. My old one started to pack it in. About once a month it would not pop out all the way and do a grind. Second attempt works fine. Once freezing temps arrived it started doing it a lot, and I noticed it was weak as well. Went to Napa to get a new one. They had two , Motorcraft, and can't remember the other but it was an odd name I never heard of. The Napa rep said the odd name one was better, but quite a bit more, and the Motorcraft one is the stock ford product. So I went with that. The odd named one looked the same except the face were the gear pops out had three black screws holding it on, were the stock one did not. Any way I get home and do the swap. Take my core back. When I started it, it was real strong which is great, but it retracted slow and would do a slight grind as it did and you could hear it keep spinning down since the motor would spin it up since it retracted slow. So I'm baffled why?? Look in the box, and there are no less than 10 small sheets of paper with ford disclosures and notifications. All for ford excursions and f350. One clearly states my issue may occur, and the solution is to replace the solenoid???? Since its built onto the starter, do I just keep exchanging starters until I get one that works?? Or is there a solenoid I can get to fix this?? Or do I abandon the ford product and get the odd named thing??
