Took a video of these parts working under the truck:
What play?Great video , I feel better about the play in my 2006 after seeing your 2011 have about the same amount. It's all good.
Thanks for posting!
Play is probably the wrong word. More like you said, a rotational tolerance. Certainly within design spec.What play?
I saw no play in any of the linkage in the video. I saw rotation that is a characteristic of the design of a ball joint.
I get a little bit of steering wheel wobble only on bad bumps at higher speeds. Maybe for a second but it corrects on it's own. I've heard other guys complain of actual death wobble but I haven't experienced that. I'm pretty sure my larger tires contribute a bit.so u get a death wobble like the older ones is this y
I'm going to upgrade the stabilizer and the shocks all the way around. The factory offerings just don't cut it for what I want. I figure since they are maintenance items and will need replacement eventually, I just as well do it now and enjoy the ride instead of suffering for a couple of years and doing it then. I'm not blaming Ford because I have made mods that have contributed to the problem.Epic, I too have a wobble and agree with your description. It is not a death wobble and not that severe but it is present nonetheless. My 08 never had it. I was thinking of changing the steering dampener and possibly the shocks. Which ones are you going with?
x2 - Was wondering the same thing!I just have to ask, how in the hell did you mount the camera to get such a solid video on the bumps, I first thought you were doing that on a rack, with someone below videotaping the turning of the steering components, and thought, "How is that going to show anything without weight on the suspension?" But you proved me wrong there! :lol:
Funny. No big deal. I use a GoPro HD which is designed for motorsports and bumpy/high vibration environments. There are many different mounts and clamps available. I clamped this shot on the front sway bar.x2 - Was wondering the same thing!
