I have been searching for over an hour and have found full instructions on how to rebuild the column but nowhere have I been able to find instructions on how to remove the column from the truck. Does anyone have a link to a tutorial or something?
It's really pretty much just unbolt and remove. Been a few years ago, but from memory just unhook the wiring plugs, unhook the automatic transmission cable to the instrument panel, 4 bolts hold the column to the truck, the bolt that secures the column to the steering shaft and you're done. Probably a couple other steps like removing some surrounding plastic from the dash. Really pretty much simply just unbolt and remove. You'll need the factory manual to get instuction to replace the bearings, all the removal steps are outlined there.
There are 4 bolts under the dash to remove the entire column, if I'm thinking correctly the size is 1/2.....And like the post above its all unplugging from there...
