my rear axle is getting loose, you can shake the drive shaft around. The U joint is good, I hope its the pinion nut that needs some tightening , but I may be in the market for a rebuild. Where can i find some instructions on the torque specs for the pinion nut, and if that dosent fix it, can i get just the pinion bearing?
