21 - 36 of 36 Posts
Whats OTA, has to do with trannys or somethin
Prob Oil to Air, as in Oil to Air trans cooler.
For a trans or oil cooler - OTA is Oil to Air and OTW is Oil to Water heat exchanger
Banned
DTRM = diesel thermal recirculation module.
The ever useful DAMHIKT (don't ask me how I know this) is missing.
How about MY for model year. That one gets me every time I see it.
whats pmr stand for....?
PMR referrs to "Powdered Metallurgy" rods. They're made by pressing powdered metals together under heat. It's an alternative to forging, but the finished product typically isn't as durable as forging. They tend to break instead of just bend.
Just about new this year is TPMS - This Part's Monstrously Stupid. Of maybe it has something to do with your tire's air.... /forums/images/%%GRAEMLIN_URL%%/wink.gif
BOHICA--- Bend Over, Here It Comes Again... used when referring to dealing with my Ford Dealer...
What's an "IP"
What's an "IP"
Probably stands for Injection Pump, used on diesels other than Powerstrokes to push high pressure fuel to the injectors. Operates like a distributor on a gasser, but instead of sending a voltage to the spark plug it sends fuel to injector at the proper time to fire it.
Not probably....definitely!!!
Didn't see these two "L"s:
LEO = Law Enforcement Officer
LOM = Lie-O-Meter (digital MPG display in instrument cluster)
Also: alternates for TPMS:
Toilet Paper Monitoring System
-or-
Tire PMS (are your tires having hot flashes?)
And, this brand-name digital gauge:
SGII = ScanGaugeII (OBD-II port reader/display)
HTH,
- Don
edited to add:
CGI = Compacted Graphite Iron (new 6.7L block)
SCR = Selective Catalytic Reduction (DEF/urea-injection on new 6.7L)
NOx = Nitrogen gas emisions such as NO and NO2
DOC = Diesel Oxidation Catalyst (diesel exhaust gas purifier)
here is the copy from Tips and Tricks on my BAZ Pages;
Acronyms - Ford-Diesel Abbreviations
2x4 =Two Wheel Drive
4L100 =Automatic Transmission 4 Super Duty Trucks
4x4 =Four Wheel Drive
ABS =Anti-Lock Braking System
AC =Air Conditioning
AIC =Auxiliary Idle Control
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BTW =By the way
CC =Crew Cab (4 door)
CDR =Crankcase Depression Regulator
CPS =Cam Positioning Sensor
DORA =Dealer Order Receipt Acknowledgment
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission on Pre-'99 Ford Pickups
EEC =Electronic Engine Control
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FAQs =Frequently Asked Questions
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
IAT =Intake Air Temperature Sensor
IDM =Injector Drive Module
IMHO =In My Humble Opinion
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OD =Over Drive
OEM =Original Equipment Manufacturer
OTC =Owatonna Tool and Equipment Company
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
PM =Power Mirrors
PS =Power Stroke
PSD =Power Stroke Diesel
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Power Window Motor
RC =Regular Cab
SB =Short Bed
SC =Super Cab (extended cab)
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTM =Turbo Temp Monitor
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Volts Direct Current
WOT =Wide Open Throttle
Glossary
AP: Accelerator Pedal position sensor Load/demand input; PCM uses this to determine mass fuel desired, adjusts fuel delivery through IPR duty cycle and fuel pulse width and injection timing; 5 volts in, 0.5-0.7 volts at idle, 4.5 volts at WOT. PID: AP
BARO: Barometric pressure sensor Strategy input; PCM uses this to adjust fuel quantity and injection timing for optimum running and minimum smoke, also glow plug on time to aid starting at higher altitudes; 5 volts in, @4.6 volts/14.7 psi at sea level, decreasing as altitude increases. PID: BARO (pressure)
CMP: CaMshaft Position sensor Strategy and load input; PCM uses this to monitor engine speed to determine engine state and load, and cylinder position in order to control timing and fuel delivery; Hall Effect sensor which generates a digital voltage signal; high, 12 volts, low, 1.5 volts. PID: RPM
DTC: Diagnostic Trouble Code System malfuction or fault codes stored in the PCM to aid in diagnosis.
EBP: Exhaust BackPressure sensor Feedback input; PCM uses this to monitor and control EPR operation; 5.0 volts in, 0.8-1.0 volts/14.7 psi KOEO or at idle, increases with engine RPM/load, decreases as altitude increases. PID: EBP (pressure), EBP V (volts)
EOT: Engine Oil Temperature sensor Strategy input; PCM uses this for determining glow plug on time, EPR actuation, idle speed, fuel delivery and injection timing and adjusts as temperature increases; 5.0 volts in, 4.37 [email protected]�F, [email protected]�F, [email protected]�F. PID: EOT (degrees)
EPR: Exhaust backPressure Regulator, also EBP regulator Output; For quicker engine warm-up at cold temperatures. If the IAT is below 37�F (50�F some models) and the EOT is below 140�F (168� some models) the PCM sends a duty cycle signal to a solenoid which controls oil flow from the turbo pedestal. This causes a servo to close a valve at the turbo exhaust outlet. The PCM monitors the EBP input to determine if the EPR needs to be disabled to provide power for increased load, then reapplys the EPR as load demand decreases until EOT or IAT rises. PID: EPR (duty cycle), EBP (pressure)
GPC: Glow Plug Control Output; The PCM energizes the glow plug relay for 10 to 120 seconds depending on EOT and BARO. PID: GPC (time)
GPL: Glow Plug Light Output; The PCM controls the "Wait to start" light independently from the GPC output; 1 to 10 seconds depending on EOT and BARO. PID: GPL.
GPM: Glow Plug Monitor Feedback input; On 1997 and newer California emission vehicles, the PCM monitors glow plug relay output voltage to determine if any glow plugs are burned out or if the relay is functioning. PID: GPML (left bank current), GPMR (right bank current), GPMC (relay output)
IAT: Intake Air Temperature sensor Strategy input; The PCM uses this for EPR control. 5 volts in, [email protected]�F, [email protected]�F, [email protected]�F. PID: IAT (degrees)
ICP: Injection Control Pressure sensor Feedback input; The PCM monitors the high pressure oil system to determine if it needs to be increased if load demand increases. It also uses this to stabilize idle speed. volts in, [email protected], [email protected] PID: ICP (pressure), ICP V (voltage)
IDM: Injector Driver Module The PCM sends a Cylinder Identification and Fuel Demand Control signal to the IDM. The IDM sends a 110 volt signal to the injectors. It then grounds each injector as fuel is required for that cylinder. Fuel Pulse width is increased to deliver more fuel. The IDM sends a feedback signal to the PCM for fault detection. PID: FuelPW Fuel Pulse Width signal from PCM (milliseconds)
IPR: Injection Pressure Regulator Output; The PCM controls the high pressure oil system by varying the duty cycle of the IPR. The IPR controls the oil bypass circuit of the high pressure pump. 0%=full return to sump (open valve), 100%=full flow to injectors (closed valve). The PCM monitors the system with the ICP input. The PCM can control fuel delivery to the injectors by increasing the IPR duty cycle which increases fule pressure through the injector nozzels. PID: IPR (% of duty cycle), MFDES Mass Fuel Desired an internal PCM calculation based on load demand (MG)
IVS: Idle Validation Switch Strategy input; On-off switch that the PCM uses to identify required operating mode; idle or power. 0 volts at idle, 12 volts off idle. PID: IVS (off/on)
MAP: Manifold Absolute Pressure sensor Strategy and feedback input; The PCM monitors manifold pressure to control fuel delivery in order to minimize smoke. It also optimizes injection timing for detected boost. It also monitor boost to limit fuel delivery to control maximum turbo boost. Frequency output; 111Hz=14.7psi, 130Hz=20psi, 167Hz=30psi. PID: MAP (pressure basline 14.7psi), MAP HZ (frequency), MGP Manifold Gauge Pressure (pressure base line 0psi) turbo boost
MAT: Manifold Air Temperature sensor Strategy input; The PCM uses this signal to adjust fuel and timing. 99 model/year engines. PID: MAT
MIL: Malfuction Indicator Lamp "Check Engine" or "Service Engine" light that the PCM illuminates when certain system faults are present.
PCM: Powertrain Control Module, also ECU or ECM for Electronic Control Unit or module The computer which monitors sensor inputs and calculates the necessary output signals to the engine control systems. It also checks for readings outside of normal parameters a records trouble codes for these faults.
PID: Parameter IDentification, also Data Stream or Sensor Data Sensor readings displayed to a scan tool that represent sensor readings to- and ouput signals from the PCM. Useful PID comparisons
AP: Accelerator Pedal--and IVS--Idle Validation Switch: IVS should switch state when AP voltage is approximatly 0.2-0.3 volts higher than base idle position.
ICP: Injection Control Pressure--IPR--Injection Pressure Regulator--and MFDES--Mass Fuel Desired: ICP should rise as IPR duty cyle increases; MFDES and IPR should rise at the same rate as load and/or demand increases (actual readings may not match); ie. ICP=500psi, IPR=12%, MFDES=10MG @500 RPM; ICP=900psi, IPR=22%, MFDES=20MG @1800RPM/cruise; ICP=1800psi, IPR=50%, MFDES=40MG @3000RPM/hard accel.
ICP: Injection Control Pressure--and RPM--CaMshaft Position Sensor: After 3 minutes at 3300 RPM, ICP pressure should be below 1400psi for Federal, 1250psi for California Emmisions, and 1500psi for 99.5. At idle, ICP should be 550-700psi for Federal, 400-600 for California and stable.
V PWR: Battery Voltage--RPM--CaMshaft Position sensor--ICP--Injection Control Pressure--FuelPW--Fuel Pulse Width: When starting V PWR should be above 10volts, ICP should be at least 500psi, at least 100RPM, and FuelPW 1mS-6mS. Once the PCM recognizes CMP speed and cylinder ID, FuelPW should default to 0.42mS, 0.60mS for 99 up, until ICP reaches starting pressure.
EOT: Engine Oil--and IAT--Intake Air Temperatures: After a cold soak, before starting EOT and IAT should be within 10 degrees of each other, Key On Engine Off.
BARO: Barometric--MAP--Manifold Absolute--and EBP--Exhaust Back Pressures: All three should indicate atmospheric pressure (14.7psi at sea level) and read within 0.5 psi of each other, Key On Engine Off.
ICP: Injection Control Pressure--and ICP V--ICP Voltage: ICP should read 0psi, ICP V should read 0.20-0.25 volts, Key On Engine Off.
EBP: Exhaust BackPressure--MGP--Manifold Gauge Pressure--and RPM--CaMshaft Position Sensor: At full throttle in neutral, EBP should be below 28psi; At full throttle in fourth (manual) or third (auto) gear, MGP should be 15psi.
21 - 36 of 36 Posts
