I've had a sticky injector for past 3 months, not too bad, not very often, usually toward end of the day after being driven around (I work in it) and only lasts no more than a minute. I decided to feed it some Power Service Diesel Kleen. I do realize I should be using fuel additives quite often, but I haven't so that's why I went and bought it.
I poured entire 16oz bottle into 21 gallons of fuel, which the back of the bottle specified to double the dose if there is an injector issue (regular dose was 8oz per 20 gallons). As a note, I got the fuel at the same RaceTrac station that I always do and is always very busy with diesel trucks. This was yesterday morning, and I kid you not it ran smoother and cleaner than it ever has. I was impressed. BUT THEN, last night on the way home, it started sticking again, and then got REAL bad. My truck barely moved and nearly cut off. After I cursed extensively for 5 min I bit the bullet and muscled it the remaining 3 miles home.
This morning it cranked fine and ran perfect. I am mystified. Could this have been bad fuel? Or possibly diesel kleen kleening the crud in the injector?
Also I bought 8oz of rev-x I'm fixing to put in when I change my oil tomorrow, could this help ?
