I bought a 1990 7.3 IDI about a month ago. It broke down three days after I bought it... driving home from work, it was like someone shut the key off. Just instantly dead. No sputtering, no power loss, nothing. No warning at all. Just off.
I thought I had run out of fuel at first, however I don't believe that is the case anymore. I have fuel coming as far as the injector pump, but don't seem to have fuel past that... at least not much. A small amount maybe, but not enough run or start. Not even close. I seem to lose pressure if it sits for a while after cranking, however I also have lines on and off trying to find where I have fuel to so I think that is most of the reason for that. I even went as far as to get an electric fuel pump and just run a line into a fuel gas and a rubber hose to differant parts to make sure I KNEW it had fuel moving through the lines.
Any ideas what else I can try? I know the lifter pump is working. I know the gas tanks are supplying fuel. I don't know much at all about the injector pump or how it works and I have no idea how to start testing it or how to check it. When I turn the key on, it buzzes and then clicks a few times. I don't remember it doing that before it broke down. I did take a voltage meter and check all the wires going to it DO have power with the ignition on.
It ran GREAT before that day. No issues at all. I really am starting to wonder if I made a big mistake buying this thing.
Any one have any ideas what else I can do this weekend. I'm pretty much ready to break down and call a tow truck and take it to a shop next week.
