After picking up my truck the mechanic mentioned that my dash temperature gauge was bouncing all over the place, setting off the “check gauges” warning light.
Since there is a delta between the coolant and oil temp I watched my oil temp on my Scangauge 2 on the drive home.
Dash gauge would jump around, drop to bottom of gauge, then peg out, and then would go dead center on the gauge between C / H , like normal, stay there for a while and repeat the cycle. The whole time the gauge was acting squirrelly my oil temperature stayed right at 200 degrees and when I slowed down or came to a stop oil temp would go down a few degrees.
Any thoughts on what I should be checking, or just a faulty sensor? I have been having an extremely small drip of coolant on the garage floor before I took it to Steinacher Automotive. I don’t know if it’s the water pump vent or thermostat housing but I plan on flushing and replacing both. Degas bottle is still just barely below the Full mark.
Thanks........ Big Horn
