I'm not sure if the title is right, I'm not sure how to explain the issue but i'll try.
A few weeks ago I changed the exterior trans filter for the first time in a couple years (I know) so now after driving aggressively and getting everything nice and hot I get a slightly different noise at idle in drive when I pull into my driveway I can't describe the noise, it's not quite a whistle or a chatter or even a hum, sounds maybe like a idler pulley with a bad bearing.
It goes away when I put it in park or everything cools down and it isn't heard in neutral or reverse.
It can also sometimes be heard when I let off the go pedal at speed and the truck returns to idle, such as slowing for a stop or turn from highway.
the truck drives and shifts normally, someone told me I had to drain the torque converter and put some additive in, didn't sound right so I'm asking you guys.
