Hi all!
My 2001 F250 is stuck in 4wd low, where do I start? I checked all the fuses as my chilton's manual doesn't have a fuse list. Could this be a relay problem? Checked voltage at the swich and switch function seems fine. Have also been working under dash on shift linkage, checked didn't see anything knocked lose. thanks! Scott
· Banned
Sounds silly but did you make sure that the truck is stopped and in neutral, and your foot is on the brake as you switch out of 4low? If you don't follow those proceedures, it will not shift out of low range.
