MY 2002 PSD has started to die, SES comes on, restart right away, went to pull codes......no codes stored. Went to AutoZone, they could not pull codes. It has also stumbled on acceleration, did not die, SES comes on. Has this happened to any one else? What do I look for? Could it be the Computer? I have another 10,000 miles before the warrantee is up.
cam position sensor.
ebay for 70 bucks. local parts store, in stock, 200.
10 minutes to replace the first time.
you will be a pedestrian within 200 miles.
Buy two, one to replace the bad one and the other for your glovebox for the next failure.
WELCOME TO TDS,, if your SES light came on, there are codes. AutoZones reader may not see them, (Not all "Cheapo" readers will work on our trucks) Find someone with a Tuner and code reader near you maybe? Or someone with AutoEnginuity computer program maybe.
It SOUNDS like the CPS, but I would NOT buy Two now, maybe get one and install it to see if the problem recurs, but if it isnt then you have TWO spares, and wouldnt need that much money layin in your glove box... /ubbthreads/images/graemlins/rolleyes.gif Really being under warranty take it to the dealer, EVEN if it is the CPS costs you the 100.00 deductible, it is not much more than buying one your self, and you KNOW what they found. (Tell them you want to know what codes it has and all..) Also you want the old part back maybe? So if the problem is not fixed then your old CPS could still be your spare???? Just a thought.
I took your advice and purchased two CPS from ebay for &113.00. This afternoon, on the way home, my truck stopped in a intersection and then stuttered twice within 1/4 mile. When I arrived home, the two CPS were waiting in my mail box. It took a little thinking to replace it, but I got it done. I hope this works.
Same problem with my 01 ....changed the cps but it still intermitantly dies while under power. Ford book says replacing the Engine wiring harness is the next step but i would like to try to find the short before shelling out that much for the whole harness. does anyone know where i can purchase a schematic for the harness. the cps is on a ground loop with 3 or 4 other sensors but i have not been able to indentify all of the other sensors.
