So long story short did the EGR and DPF delete and programmed with H&S Tuner. Truck ran great! Next morning I start it up and am now getting a sucking noise coming from the engine compartment. Kinda sounds like the front windshield defroster is on high, but lower in the engine. I can only hear this when I am building boost and goes away when boost is dropping. Anyone else have this issue or is this normal? Just trying to figure it out before something bad happens. Only difference between yesterday and today is the temperature. It is a little colder today (40-50 degrees) than yesterday (50-60 degrees).
2011 6.7 f250
Discussion Starter · #2 · (Edited)
So solved my own problem. There is a line coming off of the exhaust that goes to the wastegate sensor that came loose when pulling the egr out. Make sure you tighten it when doing the egr delete. I can post pictures if anyone has trouble with it.
