I haven't been able to figure out the magical search terms that match what I have going on.
It suddenly stalled. Would crank and go 200 feet surging and sputtering if you were deep in the pedal. Then it would die again. If you held the throttle pedal hard it would stay running just because it was surging high enough in between it dropping out and dying.
Here are videos I took after I managed to barely get it started yesterday after I plugged it in for 1hr and charged it completely.
In a couple of these videos keep in mind that my foot is on the accelerator to keep it from dying and that is what is making it rev.
Was close enough to a friends to limp it to his driveway and today I am on my third day of trying to figure this out.
The only codes thrown were CPS and keep alive memory (the second one gets thrown if you disconnect the battery terminals)
Replaced CPS yet again with a new motocraft and after clearing codes they have not come back despite it taking a couple hours to start and it will only run for 30 seconds to a minute or so.
Fuel filter replaced. Old filter was brown but not black. I am out of ideas.
I found one thread last night that suggested that if you unplug the injector control pressure sensor (ICP) that you can start it and limp it home. Is this the case and relevant to my situation?
