1 - 11 of 11 Posts
swapping a 4r100 with a e4od in a 1999 7.3 powerstroke diesel van
You'll have to drill the case for the extra sensors the 4R100 has and then reprogram your PCM for the different torque converter lockup. Not worth it. Why don't you jerk the internals and use them to rebuild your 4R100 and get a new TQ.
What if I use the pcm from the 1997?
Then your motor won't run. Plus, the wiring pin outs are different. I'm not sure about the clutch packs, but most of the "beefed up" parts are gears/planetaries. Maybe upgraded shafts. All that should swap. Who rebuilt the E4OD?
I would take both transmissions back to the shop and have them do the swap.
What rt said. Just not feasable to make the e4od work.
Sounds like you've got some serious mods. What size injectors are you running 250/200's?
Discussion Starter · #11 · (Edited)
I am running modified 250s injectors, ceramic coated cylinders, pistons and heads. Modified hpop, 3/8 inch fuel lines, framemounted fuelfiltr, dual banks turbos and hiflow fuelpump. Compression is 21/1 no headgaskets but o ringed heads.
1 - 11 of 11 Posts
