Im installing new bushings and can't find the torque specs. I did a search and come up with nothing. Thanks.
· Administrator
From 99 Service CD
Front
Sway bar to axle bracket bolts 35 ft-lb
Link Nuts 60 ft-lb (this is for the stock links that use a captive bolt.)
Rear
Sway bar to axle bracket Dana 30 ft-lb, Ford 35 ft-lb
Link Nuts 52 ft-lb (this is for the stock links that use a captive bolt.)
If you're using the ES kit, they should give you torques for the link bushing bolt and nut, but I'd guess it would be in the same range as stock.
Yeah I got the ES kit but the only info that came with it was where to grease the bushings on installation. Thaks for the info. BTW I bet you are liking the PDF this year. 3,200! I really miss Anchorage/Eagle River.
· Administrator
I thought I remembered your username as local. Yeah the PFD/fuel rebate was nice. bought my truck a birthday present.
Sounds like you got an all-expense paid trip to the South.
I was there (Phenix City) once and made sure I didn't leave anything behind.
