I have an SCT X4 and I'd like to switch tunes from IDP to PIP.
My understanding is that I need to update the tuner, load the new PIP tunes, and then tune the truck overriding the IDP tunes (not putting the truck back to stock).
Reason for doing so is I've found out IDP is no longer making delete tunes so should I have any issues I'll have to do this anyway.
My concern is going to stock and then loading the new tunes because I won't have installed the dpf. I guess that wouldn't be an issue if I didn't start the truck though right?
Anyone else do this? I ask on another site and didn't get any helpful replies.
Thanks.
I'd suggest going back to stock, use the LOAD THIS FIRST file, then load PIP. You shouldn't have problems since you will not be starting the truck.
I'll try this weekend and see what happens. Might just drop it off at local shop and let them mess with it.
Reactions: HeavyAssault
