1 - 10 of 10 Posts
If diagnosing convertor rattle would you still here the rattle for about 5 seconds or so after you turn the truck off ?
Yes, everything is still spinning, although it sounds like the TC has come apart internally..I would consider addressing the problem very soon.
Yep, you need a TC, and quick!!! You can use the one that they put in the 6.0 that is suppose to be a more heavy duty unit for around $400. This is what I would do, then when the tranny goes call Brian at BTS.
Go to directfordparts.com. I had the exact same problem. replaced with a OEM TC and since I'm running stock I saw no problem. I was very surprised by the difference. And the price won't kill you either. 325+100core+shipping. Core is returned when they receive it back. They are part of Gaudin Ford in Las Vegas.
I'm sorry guys I may have posted in wrong section but all set aside the torque convertor is a ATS 5 STAR Viskus Clutch Drive, and my thoughts of it so far, junk... along with ATS Trans Stage 3. Thanks
5 disc Tc is going to be a little more rattling then other stock TC.
Did you check to see if something is loose inside the bell housing?
Chances are your t/c is fine, so long as you are not getting any slippage or excessive temps. Like was said multi disk t/c's are more noisy than a stock t/c, some more than others. I have no experience with ATS products but I have a Precession multi disk t/c and it is rather noisy. I suppose you could get a single disk t/c and that would be more quiet.
Other than the t/c noise have you had any other problems with the ATS trans or t/c?
none_left,
Please fill out your sig, it will help folks when trying to help you, list everything you can about your truck.
Aww come on NChornet that takes all the challenge out of it. /ubbthreads/images/graemlins/biggrin.gif
You just got to know what questions to ask before condemning things.
1 - 10 of 10 Posts
