My 92 w/zf5 has a tach that's reading funky. It seems to read a little low at idle and likely low also at rpms up to 2000 or so, but if I get into it over 2200, it pegs all the way, then comes back when it gets under 2000 or so. I have removed and ohm-tested the sender, it's reading about 2500. The wires were showing some copper where they enter the unit, but I filled around them with some liquid plastic electrical compound. There wasn't any sludge or metal flakes on the sender when removed, but I cleaned it with parts cleaner before reinstalling. I have removed the dash cluster and cleaned the connector/printed circuit connection on that side. I was under the impression that the sender wouldn't be responsible for a overtach reading (high voltage?) like the one I'm seeing. Am I misinformed? Do I need to look at ground issues or can I have a bad diode or something in the gauge? All other gauges/electrics seem to work perfectly.
I don't know how the cluster grounds, and I'm a little leery about going into the dash again. I had to fix a lot of plastic clips with 5-minute epoxy last time...plus it seems that a replacement tach gauge might me hard to come by. I'm just hoping someone can give some insight before I start throwing parts at it. Any ideas?
The tach sendor signal mixes with the VSS signal in the eprom mounted behind the cluster. Check the VSS on the rear axle.
VSS tests at 1292 ohms, which is within spec, according to what I've read about it. I would think that if it had a problem I would see that reflected in the speedometer?
