Which way does the tapper go big end towards the rear? or big end towards the front? I alway thought the big end towards the rear with the wedge toward the front would be the right way. After looking at it if I put the big end towards the front it looks to turn the rear end upward putting less of a angle on the drive shaft.
Thanks for any help.
Jeff
Jeff
Put down the crack pipe Jeff... /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/rolleyes.gif
Taller end to the rear.
This lessens the pinion angle (what you want).
Dave
ON EDIT:
I just saw which truck you have. Why are you putting a tappered block on it. It didn't come with a tappered block, it doesn't need one unless you go REALLY high.
You have a two-piece rear driveline and a tappered block will screw-up the angles. Reconsider this.....
Thanks thats what I thought - just wasnt sure.........
