Hi, there are a few threads for my transmission pan that have been stripped. Some of them I have either re-tapped or ran a bolt all the way through with a nut.
However, there are some in the front that I am worried about.There is no place to put a nut on the other side of the bolts that are in the front part of the pan. The holes go right in the tranny. I stuck some copper tubing up in there just to make sure that it is open and I dont drill through anything else, it seemed fine to do. Now I am worried about drilling and tapping, which would cause small metal shards to be on top of the holes and possible mess something up. Do I need to worry about this?? Or does anyone have any other ideas of how I can fix this problem??
158572
158573
Stick some wheel bearing grease in the hole before drilling and tapping. That will trap the chips. Be sure to wipe the grease out before reassembling.
Unfortunately I run into this frequently and I always drill and install a thread insert like a Heli-Coil.Typically I perform thread repairs when the pan is off but I have done one offs with the pan on. The grease truck mentioned works well.
I usually grease the flutes of both drill and tap. Then wash it out, what gets away...well that's what good filters are for. I also use a heli-coil, or something like that because the aluminum won't last long if it's already worn out enough for you to have to make repairs
Reactions: klhansen
