Hey y'all, I've come to y'all for help many times before so I figured I would finally post about my best project yet. I have a 1991 F250 7.3 2wd with a bad E4OD in it and my plan is to put a ZF542 in it out of a 1994 2wd with a 7.3 turbo (not powerstroke) since that's what I had sitting around. I know the flywheel is different and the newer transmission doesn't have a speedometer gear. Other than these minor set backs what else do y'all know of I might run into a snag with when I'm swapping these? Will the driveshaft work out of the 94? Any suggestions on an aftermarket speedometer that will work? I didn't see a place to hang the swing bearing so I'm guessing I'll have to build a bracket for it if it will work.
